Re: Hubcentric rings.
I put this on a 2005 NA front hub they are the MB spacers and are hub centric, not sure if the SRT hub is the same. Stock bolts are 40mm you will need longer bolts if you add a spacer, just add the spacer width to 40mm for the right size or a plus 5mm and they will stick out about 3mm on the inside of the hub.
Dan
