Re: Another 3.7 swap
Update:
Finally have my used motor, a 3.7 from a 2005 ML.
My Lincoln MKT is loaded with parts I will be dropping off tomorrow morning. As long as a new engine is being installed, I wanted to take care of the following.
-Upper(Mopar) and lower(Gates) radiator hoses and new antifreeze
-Luk Power Steering pump with every line(high pressure, return, cooling) from Gates(was noisy) with fluid
-idler pulley
-Gates belt
-Beck Arnley water pump
-Luk Clutch Kit
-Centric master cylinder with blue brake fluid
-Felpro gasket kit
-NGK wires and Autolite iridium spark plugs
-mobile 1 oil and filter
-mobile 1 oil for trans and gear fluid for diff
-K&N air filters
-exhaust manifold gaskets
I am also having new rotors and pads installed and was considering having SS lines done at the same time.
AND I also have spring and shocks ready to go in. I might do this separate because I want to make sure I have the correct camber parts that I haven't researched or ordered yet.
Anyway the car is getting some serious love here.
I'll be updating again soon!
