Herman Minister
Okay, so my next question is where would I find the main fuse? I have a 2007 roadster automatic. I found the small fuse box in the side of the dash, and there’s another alongside the battery which contains 3 or 4 small fuses and one larger 40 amp fuse (so not the main). I can find no box in the trunk. Is the main fuse even located in a fuse box, or is it on a bulkhead somewhere? Again, any help would be gratefully received.
What you found was the fuses on the Relay Control Module (RCM), the main fuse is just in front of it where the previous posts arrow points to.
