Old May 18, 2019 | 02:29 PM
Squirrel Crusher's Avatar
Squirrel Crusher
Default Re: Killer Chiller kit installed need help
unless you are switching water paths with solenoids, the oem heat exchanger should be taken out of the system and the AC compressor should always be running when the car is.
Maybe I should be asking this question in smaller groups. With a converted MID wet sleeve engine,it's more or less a 3 season engine. The engine oil is recommended to be at least 60 degrees during start up's or a engine block heater needs to be added. Wouldn't this be an exception for the compressor to run at all times? Squirrel Crusher
