Old May 22, 2019 | 03:03 PM
onehundred80
Default Re: My fog lights won’t turn off.
Originally Posted by 022008
Onehundred80,
your call was spot on. the unit was sitting in 3 inches of water. the lights have turned off, only to go back on and stay on. i take it i'll need a new pump.
would a new used pump need to be flashed by stealership?
No it is plug and play. You can find them on eBay all the time.
Make sure you get one that has the plugs and pig tails, you do not want to use your old plugs as they will be corroded as well most likely. When you get the new pump you should try and clean the old plugs to see if they work, if not you splice in the new plugs.
It would be nearly impossible to just buy the plugs after you have got a pump. Good luck, it is not too hard to do, but find and fix that leak or you will be doing it again.
