Eliminating air cond probs
Hi all, I'm in the process of trying to eliminate issues with my air con.
The clutch is not engaging but the light comes on when pressed on the console.
I have replaced the head control unit and still have the same issue. I have checked the fuses they all look fine..question here is can a fuse look fine but still be bad? Or does the wire need to be broken in the fuse for it to be dead?
The heater/cooler fan is working fine..erratic speed but I guess that's nothing to do with the clutch not engaging.
The compressor spins fine by hand.
Just trying to cross things off before I go for a evac and refill to see if it's a low pressure cut out.
Thanks
Ed
