Youngautomechanic
I ordered a "working" used Central Locking Pump. Maybe it kills two birds with one stone. Because not only does my roof not work, my door locks don't want to lock by key fob or switch. I did remove Central Locking Pump and it was filled with water. Opened her up and the motherboard was corroded And definitely not able to be functional. So I'll post back when I put new module in, in a couple days.
I just bought my first crossfire a 2005 limited. It was cheap and needs work. The main fix it's exactly what is going on here i believe. The switch just blinks. Opening manually is easy and when you let go of the top it slowly goes down with gravity showing that it has some hydraulic pressure. Can you guys help with a little more detail of checking the central locking pump module? Also my locks on the door do not come up or down with the key fob but the head lights do blink when pressed. I thought this was do to aftermarket viper alarm that was installed and also is not working. I love this car and don't mind putting a little love back into this.
