Thread: No start
Old Jun 6, 2019 | 07:51 PM
onehundred80
Default Re: No start
Originally Posted by Oldfordman
I am working on a 06 cry. Crossfire. The customer had it at the dealer, they looked at it replaced the pulse module couldn't get it to run and said didn't know what is wrong. They brought it to my shop. I checked for codes with my snap on and mac scanner has codes for steering wheel angle sensor no engine codes. I tried to start would not removed battery cable for a min. Still no start, noticed fuel pump not coming on, remote not working. So I removed the rcm resoldered the two common points that fail, retest and it will start and die on the second try only. Not your typical three start when the skreem module goes bad. I also checked the central locking pump, no signs of water or connections issues. I found that if you press the remote and the lock in the car the infrared lights up on the remote does anybody have any ideas what I'm dealing with ?
That is not an infra red transmitter you see, it is a battery tester only. If you have seen the light then all is good. Hallelujah.
