TPMS light on - Sensors Ok
Hi Everyone,
I purchased a used 2004 crossfire about one year ago, which is having the TPMS lights on since I bought it. The seller mentioned that probably one (or multiple) sensors were to be changed.
So I recently went to a famous tire shop to replace the tire pressure sensors. Surprisingly, they tested all the sensor, and according to them, all were working fine. They recommended to go to the Chrysler dealer, to “reset/change the computer”, which I did. The Chrysler dealer requested to book a 1 hour investigation.... for 180$ (only for investigation).
1. Has anyone else had the TPMS light on, but sensors emitting fine?
2. Is there another way to fix it, without going through official dealer?
3. Has anyone tried a tool like the one on the link below? Would it work for this issue?
Autokcan Tire Pressure Reset Tool for GM,OEC T5 EL-50448 Auto Tire Pressure Monitor Sensor TPMS Relearn Activation Tool https://www.amazon.com/dp/B07QCXFF46/ref=cm_sw_r_cp_api_i_PuDaDbWESDMGQ
Thanks a lot in advance!
