Well I removed the lens assembly -- and really
- dash type bulbs that you need to remove the bus bar board to get out? These are old fashion dash illuminating bulbs-- the whole base that twist into the board is the bulb - plastic and all? How in the world can you find that .. I would assume you would replace the bulb base assembly with the base that goes back in the hole and then you could replace the bulb with and LED type...
