Old Jun 16, 2019 | 12:16 PM
  #6130 (permalink)
onehundred80
Originally Posted by Groucho
Well I removed the lens assembly -- and really - dash type bulbs that you need to remove the bus bar board to get out? These are old fashion dash illuminating bulbs-- the whole base that twist into the board is the bulb - plastic and all? How in the world can you find that .. I would assume you would replace the bulb base assembly with the base that goes back in the hole and then you could replace the bulb with and LED type...
The cover over the bulb slides down and out and then you just pull the bulb out and replace it.
I recall it is a wedge base bulb, I’ll check.
Here is the bulb I used, you can see the dome-shaped lens at the front of the bulb, no light is lost sideways.
