Old Jun 17, 2019 | 06:16 PM
Chooch's Avatar
Chooch
Default Re: Check Engine Light ON...... any ideas?
Yup. You need a new part - Bosch Camshaft Position Sensor part number #0232103037.
It's very simple to replace, see:
https://www.crossfireforum.org/forum...tionsensor.pdf
Failure to make this replacement can result in a shutdown until it is replaced; usually happens at the worst time at the worst location.
Listed on Amazon:
https://www.amazon.com/Bosch-Original-Equipment-0232103037-Camshaft/dp/B001COB2DC/ref=au_as_r?_encoding=UTF8&Make=Mercedes-Benz%7C63&Model=SLK320%7C855&Year=2004%7C2004&ie=UTF8&n=15684181&s=automotive&vehicleId=1&vehicleType=automotive https://www.amazon.com/Bosch-Original-Equipment-0232103037-Camshaft/dp/B001COB2DC/ref=au_as_r?_encoding=UTF8&Make=Mercedes-Benz%7C63&Model=SLK320%7C855&Year=2004%7C2004&ie=UTF8&n=15684181&s=automotive&vehicleId=1&vehicleType=automotive
Also see the (nearly) complete list of documentation, repairs, and modifications provided by onehundred 80:
I would also consider replacing the Crankshaft Position Sensor, making the RCM repairs and the Sticky Key Fix if you have not already done so.
Better safe than sorry.
