Old Jun 18, 2019 | 07:42 AM
zip439's Avatar
zip439
Default Re: Check Engine Light ON...... any ideas?
Kourt78, I see you are from Annapolis, MD so I am certain you have much more money than I to keep throwing at your car. However, if you will use the search box at the upper right corner of this forum you will will find that the "Sticky Key Fix" is a one time repair and will cost you $ zero, and the RCM repair when sent off to forum member tighed1 will cost about $30 and his repair and improvements will last at the least 5 years and probably much longer.
Your choice.
I recommend you become pro active and save a bundle.
