Re: Strange noise from driver side rear on acceleration/shift.
if u changed wheels check the lug bolts
on your exhaust did u use a screw clamp anywhere (they work loose and make a loose metal noise
center bearing on drive shaft or boot on center bearing
e-brake cable rubbing shock or loose shock
