Old Jun 20, 2019 | 07:23 PM
zip439's Avatar
zip439
Default Re: AC Compressor Bad?
The connector is located in the large black plastic box just inboard from the battery. Slide the latch to open. Inside the box are the three module RCM Relay Control Module, PCM Powertrain Control Module and the BCM Body Control Module. On the front wall of the box is the connector 106. That is what you are looking for. It simple connects the wires from the interior A/C control module ( The heat and cold wheel adjustors) to the AC compressor clutch. Open that connector and jump 12v directly from the battery to the A/C clutch to test the compressor clutch. It is the number 3 pin. This bypasses all the sensors so you know if something else is preventing the compressor from engaging or the clutch itself has gone bad.
All this info is in the service manual available for download on this site.
click: https://www.crossfireforum.org/forum...s-repairs.html
