Re: 2005 convertible top not operating
Thanks pizza - so removing fuses 5/6 didn’t work, but disconnecting the battery did result in my manually being able to raise:lower the top without resistance or needing to do the hydraulic reset procedure. It did, however, also result in my windows no longer going down when the center top d lock is turned. Does this suggest both a tcm and a solenoid issue?
