Old Jun 22, 2019 | 06:19 PM
hemifiedbird's Avatar
hemifiedbird
Default Alarm Issues and Locking Issues
Our 05 Vert was in the garage with key in the ignition, No one was near the car for a month, Went to move it and the doors were locked, key inside. Towing lock button flashing on console. Had to break into car as cannot find second key. Got into car and alarm was screaming lights flashing. Hit remote and it would not clear. Killed the power on the master switch and put in new batteries in remote. Still will not lock or unlock car. Lights flash but alarm does not go off as i have pulled the fuse on #9. Hooked a scanner to the car and it has a panic button on remote shorted code. Cleared the code and the car is the same. The Towing lock button is still flashing. The car will start but shuts off right away so the alarm must still be activated somehow. Anyone have this happen or any ideas what to try next. Battery is 3 months old and load tested, it is fine. Cables clean. Thanks
