Da55id
So, I installed the SL55 Kompressor fuel pump and while I have not yet done a dyno run, I can say with certainty that the power has been restored (at least) at the 4000-6200 rpm range. Although the butt dyno is not a valid test, all I can say is that my smile meter is now pegged when I hit the slanty pedal. I double checked with Jerry at Eurocharged and he said that I DON'T need a new tune and I should definitely expect that there is more whp now that the fuel is up to snuff. Once things get a bit warmer around here, I will get a dyno and a/f check to see where we are for a final report on the Needswings/Waldig Crossover tweaked manifolds.
Cheers,
Dave
Hi Dave, have you already dynoed your car - I think many here are interested in your results (afr and hp).
