Old Jun 27, 2019 | 05:00 PM
Tbirdtony's Avatar
Tbirdtony
Default Re: Front Coil Springs??
onehundred80,
Took my 04 Crossfire for its' Pennsylvania inspection today and found that the right front spring is broken. I see that NeedsWings sells the front two coil springs for $187.95. I saw your comment about used springs but I don't want to install used springs. Do you know if anyone else sells new front coil springs for the Crossfire? I'm going to checkout RockAuto. Maybe RockAuto has springs listed for the Mercedes 320 SLK which should be the same as the Crossfire springs. Any comments or help you can give would be appreciated. Thanks in advance.
