Old Jun 29, 2019 | 09:17 AM
BarbarianCBX's Avatar
BarbarianCBX
Default Re: 2004 Coupe Questions-Locks and Instruments Illumination
The lock switch is under the radio.
The key has to be in the ON/RUN position, this is the position just before the starter operates, the first position is the accessory position.
Maybe you are doing this but maybe not.
I meant under radio, not clock. I did that procedure several times. When I push the top of the lock button for more than 5 seconds should I hear a beep or some other signal which I don't?
