Old Jun 30, 2019 | 07:10 AM
dedwards0323
Default Re: AC blower stopping and starting
I did the same thing Dave, mine looked OK to me also.
I hesitate to do it again because of the nightmare of aligning those 2 square plastic shafts on re-assembly.
Originally Posted by CL770
Some folks state that the temp wheels on the front of the unit need to be removed to separate the housing from the front. But I see in your pictures provided with your original post on this fix that the wheels look to be still attached. Do I need to remove the wheels to reach the 8 tabs that need to be moved to separate the housing from the front cover?
Hi, you don't need to remove the temperature wheels or the control ***** to separate the unit from the housing. Just get a couple of small flat screwdrivers to hold the tabs back and pull it out of the housing.
I reached out to CL770 about having to remove the temp wheels & control ***** to disassemble the HVAC Control Module. The pictures he included in his original post showed these still attached. I received the feedback above.
