Re: Removing 48 pin plug cover?
See if this makes sense to you: lift up on top part while twisting a screw driver blade between the edges to force connector open. The outer cover can be removed first by pulling it at the top.The cover snaps into the "handle" of the connector which you will pull up once the cover is off.
