Netwizz
Hi all
My 2004 roadster yesterday failed to start. The battery is fine. just nothing when I turn the key to the starter position. Everything else electrical seems to work fine.
Looking through the forum I found this great post, and as my fan does start up after a number of seconds, increasing to hurricane speed! I removed the relay module. Nothing obviously wrong here and all soldered joints look good and shiny, no sign or a dry joint. None the less I went through and re-soldered as suggested.
Refitted the module but no change!
removed the module again and checked all relays do work and buzzed out the open and closed contacts were as expected!
Any ideas guys? I'm at a loss as to what to look at next?
Mark
You say the battery is fine - have you had it checked or is it just fully charged?
Also - with the fan running at high speed, I think that is an indication that one of the relays has failed, can't remember which one.
