Re: Vacuum Line Inquiry
Vacuum line wye(Y) connector? If you can't get the exact part replacement, I would guess that a same size diameter wye or tee in rubber or even hard plastic would work. You may need to get creative with slightly different diameter rubber vacuum hose to get everything together air tight.
