Old Jul 10, 2019 | 04:42 PM
GraphiteGhost
Default Re: '08 roadster will not start
Originally Posted by Barbarasouix
The battery was okay it was a new deep cycle battery (whatever that means) until I killed it when the dash lights wouldn’t turn off no matter what even when the keys were taken out. They still stay on when the lights are in the off spot and turn off when they are in the on spot. Weird
Did you check if you have water in the rear lower compartment (below the Styrofoam inserts under the rear carpet)? There is two rubber plugs under the rear compartment from under the car, stick a phillips screwdriver into the center of the right plug until it punctures that plug. If water comes out, you have a flooded locking module. Come back in to tell us if that right side is flooded. Good luck!
