Old Jul 10, 2019 | 07:29 PM
Barbarasouix's Avatar
Barbarasouix
Default Re: '08 roadster will not start
Originally Posted by ZERACER
Also FYI, you said you disconnected and reconnected the red cable from the battery. NEVER ever disconnect and reconnect the positive (+) side if the battery. Always do the negative (-) side first so you don't short or spike the electrical connection. This causes all kinds of problems with computer modules.
Did you check if you have water in the rear lower compartment (below the Styrofoam inserts under the rear carpet)? There is two rubber plugs under the rear compartment from under the car, stick a phillips screwdriver into the center of the right plug until it punctures that plug. If water comes out, you have a flooded locking module. Come back in to tell us if that right side is flooded. Good luck!
No the man said it’s not flooded in there. He said he can’t communicate with the ECM or the Skreem he said he thinks it’s the Skreem and said if I order it he will replace it off his work clock for 360 but that I would then need to call a locksmith to program the keys. I think I’ll try and do it on my own following the directions here.
