Thread: Magna Flow
Old Jul 19, 2019 | 10:42 PM
James1549
Default Re: Magna Flow
First remove the bracket crossing under the pipe towards the muffler. IIRC, you need a large torx bit. Also remove the 3 flange bolts first before trying to remove the two rubber donuts at the muffler. Removing the flange bolts will allow the system to be pulled to the rear so there will be less tension on the rubber donuts.
James
