onehundred80
Have it your way, but I have not seen that mentioned on here before, the OEM ones are pricey and if you mistakenly tighten the screws too tight the lens breaks.
I have ordered four sets and they all arrived safely and worked fine. 98% positive feedback.
CLICK
I agree with onehundred80 that LED is the best way to go but if you MUST have the original OE part with a little 3-pointed star on it they are only $14.29 here, which is less than I've found them anywhere else.
https://mercedespartscenter.com/part...agramCallOut=2
Notice that the original part number of
2308200256 has been superseded. Also notice that I did the leg work and found an actual Mercedes vehicle which uses them (2004 CLK320). If you are smart you will pretend that is the car you have when ordering from these people. Google 2004 Mercedes-Benz CLK320 VIN and use one of the 17-character codes. Or be honest and tell them you have a Chrysler Crossfire. See where it gets you.
