Old Jul 28, 2019 | 10:10 AM
onehundred80
Default Re: Amateur engineer fixes the Crossfire
Originally Posted by WD40
I like post #10 in your link. Sounds like a winner. Otherwise the only shortcoming is once everything is tidied-up the need for "Back-To-Black" becomes achingly apparent. Walmart it is then, because whilst O'reilly has Back-To-Black I'm pretty sure they don't have "large kitchen trash bags"... lists dictate my life. I have a 3-product process to restoring rubber seals to like-new in most cases. The secret product is used in between the other two. It is AT-205 Reseal. Spread it until the rubber is wet and within an hour or so it will be absorbed by the rubber which becomes plumped-up like new. I used this process on the 4/5-feet long rubber seals at the base of the windshield and atop the cowl.
The trouble with that fix is that the result still looks off centre.
