Old Aug 3, 2019 | 03:22 PM
onehundred80
Default Re: Car wont start-Immobiliser issue after charging battery
Originally Posted by AussieXFire
Car sat for a month while overseas, hence the battery went flat. Charged up the battery, after reconnecting, the headlights are on, the indicators are flashing, the car attempted to start, and the key fob will not lock or unlock the car. The key fob has the flashing light when the button is pressed, so the key fob battery is ok. I'm at a loss as to how to remedy this.
Simple check, are the flasher stalk, emergency flasher and headlight switch in the OFF position? Maybe fob needs to be reset.
How old is the battery?
