Old Aug 7, 2019 | 11:54 PM
onehundred80
Default Re: Pressure points for jacks for an oil change
The engine pan cover keeps the engine cleaner and reduces drag, so keep it.
Get an oil extraction pump to suck the oil out of the sump via the dipstick tube.
Get a minimum ten litre pump and you will find it much easier and cleaner.
After the first drain let the engine sit fir an hour at least and you’ll get more oil, do this on a warm but not hot engine.
