Old Aug 13, 2019 | 05:09 PM
onehundred80
Default Re: Auxiliary pump for inter cooler (supercharger)
Originally Posted by Fla_Xfire_SRT
I was hoping this thread had a little more info, mostly concerning the hoses for that intercooler pump. Are there 4 hoses to the pump, 3 to the bottom and one to the top? Is there a more specific link that might have photos of the pump repacement? EDIT> Tigheds supercooler install shows a lot as well as the johnson pump install. Does the frontmost hose closest to the radiator that seems to attatch from the top on one end attach on its opposite end to the water pump? I can see one going up to the recovery tank, and two going to the intercooler coil. The fourth one is a bit of a mystery. Thanks in advance.
The Johnson pump install shows everything more or less, one of the hoses is not used now on the (010) pump I connected the little hose to the little dummy nipple anyway, I think it was a drain hose originally on the OEM pump (02) not sure now though.
New pump part # 0392022010 they are $113 on Amazon.
