Old Aug 15, 2019 | 02:15 PM
onehundred80
Default Re: supercharger not working
Originally Posted by Ranger413
Looking for some help/direction. This thread is a few years old, but is at least on topic. Supercharger is cutting in and out. Dealer says I need to replace the clutch (over $1000 for the part, wth) after recent visit. It seem worse when it's hot, but when it happens it is consistent the way it cuts in and out. Any way to confirm SC clutch is the issue.
The common cause is an intercooler pump that has failed and the coolant gets too hot, usually that means the car runs fine from cold but when it warms up the SC quits working The air entering the engine gets too warm. I cannot see the SC clutch causing that problem unless the electro magnet is failing, causing slippage.
Check for engine error codes and see if the pump is working, how many miles on the car?
Bosch pump part #0392022010 - $113 on Amazon.
