Re: Starter wont engage.
You might consider that the small flash of current you see when trying to start might indicate a loose/bad connection. The connection might be good enough to briefly make a circuit but not good enough to carry any amps, even the low amps to operate the solenoid. Maybe there might be a way to install a jumper between points in the starting circuit. You might even have a broken wire.
