Old Aug 17, 2019 | 02:33 PM
RL67037's Avatar
RL67037
Default Re: Pulse module NOT sending signal
Originally Posted by Oconnom
Pizzaguy,
Have you seen my replies to your questions in the thread 'RCM' as you requested ?
Also, the only connection between the PM and ECM(PCM)is the Pink/Red wire from terminal 2A. It is marked 'sensor ground' which seems to be the mis-labelled connection ?
Mick
Mick - did you ever figure out your problem? I am in the same boat - no starter engagement. New battery on 8/16/2019 and RCM was rebuilt by DJ. I am getting a 1/2 second pulse of 12.5VDC at 1F from the PM (but the starter doesn't even kick) then nothing. If I connect 12 VDC to pin 6 of connector C106 (the other end of the wire from 1F), the starter wil engage. Did you find out or prove what (if anything) gives the PM the "go" or "no go" command?
Thanks - Randy
