Old Aug 20, 2019 | 04:16 PM
onehundred80
Default Re: Pulse module NOT sending signal
Originally Posted by RL67037
I did, however, figure out that when there is 12VDC on B2 of the Pulse Module, when A2 is pulled to ground, the starter relay closes and passes the 12VDC to F1. I assume that ground for A2 is coming from the PCM since A2 is connected to connector C4, Pin 35 of the PCM.
I know you saw the relays working but are the contacts clean? Dirty contacts will not complete the circuit if they are too damaged.
The RCM seemed to be the cause of the trouble as noted in other posts.
Somehow I doubt your problem is as complex as you are making it, we can get carried away with our problems and end up not seeing the woods for the trees.
