Old Aug 20, 2019 | 06:01 PM
zip439's Avatar
zip439
Default Re: Error code P0410...& all these Secondary Tagalongs
There is a common theme. The 02 sensors and the code P0410 for the air pump are related and could clear with one fix. The EGR valve, and coolant temperature sensor may be something else.
The longer you ran with the check engine light on the more codes it could have piled up. None of it sounds too serious.
