Re: How to remove the front headlight assembly
AND ! If you are talking about the 'brow' lights up in the outer corners, then those can be changed using a long open end 10 mm wrench endwise to turn the plastic/rubber bulb holders.
You will also need some skinny needlenose pliers or hemostats.
