Old Aug 21, 2019 | 10:31 AM
DTMenace's Avatar
DTMenace
Default Re: Auxilliary Pump hoses
Originally Posted by Fla_Xfire_SRT
New hoses arrived yesterday. Can the IC pump be changed from the top? or, passenger tire and inner fender liner Must be removed first to gain access? Thanks.
Fla_Xfire
Definitely removal/replacement can't be done from the top. It would be ideal to have access to a lift to remove the passenger front tire and inner liner to access the IC pump. Don't forget to have clamps available to reduce the loss of fluid during the process. There is a pictorial on the process, if you use the search button.
Good Luck....
Dennis
DTMenace
