Old Aug 23, 2019 | 03:04 PM
Carmona_1107's Avatar
Carmona_1107
Default Re: No blowing, air speed matches outside air.
Originally Posted by Jslav95
So I'm new here, and I've joined because my crossfire is having a pretty weird problem. First, my cars air conditioning and vent system filled up with water after a hard rain. I learned that this is because a ton of leaves fell and clogged up the drain holes under the windshield. I thought I fixed the issue with towels and a box full of rice to help my car dehumidify. Then, just a couple days ago, my car stopped blowing air from the air conditioning or heater. I can't hear the fan blowing when I turn it on, but if I leave the heat on while driving, air starts blowing in even without the fan. It blows harder the faster I go, so I'm assuming it's because the car draws in from outside air. The biggest issue is that I can't use my heat when at a stop or traveling slowly. Does anyone know how to access the blower motor or has anyone dealt with this problem before?
Yes I’ve dealt with the water part... I’ll get 3-5 inches after a big storm.
Move cleaned out the holes under my windshield, yes they were clogged with Debris. It’s still happening...
my AC won’t work at all! Nothing comes on & I don’t here the blower motor engaging.??
so have you figured anything out??
