Old Aug 29, 2019 | 11:09 PM
jeffsrawr's Avatar
jeffsrawr
Default Re: Top operation intermittent
Originally Posted by UrbanE
Roadster top issue
Goes up and down just fine
Start the car, hit the button roof goes down and I go for a spin. When I return and press up button, I get the beep warning and top does not raise
I turn the car off and then back on. Press the top up button and all works. I can’t work it out.
Has anyone experienced this?
Do any of you have any idea as to why it will not cycle down and up in the same run without having to turn it off and on again.
It only happens after a drive.
On the driveway up down is fine in the same cycle
I’ve changed the switch (I now have several and it’s still the same
If I do nothing other than turn the car off and on again it works and I can put the roof up.
Any ideas
that was an issue i had before it quit working all together, check that stupid switch in the passenger top frame i talked about earlier in the thread. it prob needs bent back into shape.
