Re: Key Fob/Remote & Central Locking
Hello I own a 2005 Crossfire I got in Oct 2018 . I love this little car !! and I wanted to tell you under that panel where the washer nozzles is where the Siren alarm is . I do believe it is fried . My siren never worked it is in a bad place because the cowl fills with leaves and junk esp if left outside under a tree . and then get clogged up and then fills with water. My cowl in my Crossfire was filled with all sorts of leaves and dirt. My 2011 Mustang had the same problem and it over flowed into the pass compartment . if you unplug the Siren and try to redo the fuse it may fix your problem . I tried to replace the siren with 2 ebay purchases and neither of them work the lights only flash which is ok. The electrical system on this car is very tricky and I would not mess with it. This car is becoming a real problem as things go wrong with it and parts that it may need electrical esp the Skreem will kill your car forever never loose or damage your keys or remotes and never loose your transponders or you will have a very nice lawn ornement because you will be paying for a key you may never get because they are very hard and expensive if you even can get one because Chrysler wants you to pay ahead of getting it $500 to $700 for a flip key and Mercedes does not support these models any longer treat your keys like expensive pieces of jewelry . Best of luck hope this helps you ; )
