Re: convertible top help pt.2
when you go to move the top manually notice the latch position of the rear bow. the weatherstrip should be pulled firm against the tonneau cover. if it's not check for hydraulic fluid leaking from the main cylinders and make sure you manually latch that rear bow to prevent water entry.
