Old Sep 10, 2019 | 11:17 AM
onehundred80
Default Re: I need some help replacing head unit.
Originally Posted by Tom3120
So I did some research last week about replacing my stock head unit. I decided to go with a Kenwood KMR-D375BT. I want to use all factory speakers. So if I’ve read correctly I will need to also buy a Scosche VW01B harness to properly hook up the unit to factory wiring. I’ve also read that I “might” need an antenna adapter??? Does anyone know if this is true and do I need a male or female adapter?
at first I was thinking I could get this changed out before the trip to the Dragon in 3 weeks but I’m just unsure of what all I need to order. This may end up being a winter project.
So, head unit, wire harness and maybe an antenna adapter. Anything else?
Here is what you need for a Kenwood install. CLICK
You need the antenna adapter shown in the PDF unless you are replacing the navigation radio which already uses it.
