Re: Seat Relay
Replacing the Power Seat Relay
A couple our members have had a problem with the powered seats not working.
Normally this is caused by the seat relay malfunctioning.
The relay replacement can be replaced with the following relays.
MB #002 542 22 19 Siemens Part #72KD305 or Chrysler #05104857AA
To gain access to the solenoid remove the lower dash panel on the driver’s side. Taking the lower dash panel off is a pain, lots of screws in an awkward spot. It can be lowered without removing the headlight module.
Working under the dash is quite awkward and a light is required to see the positions of the screws.
