Old Sep 16, 2019 | 06:14 PM
UrbanE's Avatar
UrbanE
Default Re: emergency trunk release handle 2005 roadster
Originally Posted by Johnny Versatile
Hey Urban E Where do I find that unnecessary switch which I should undo?
I had done this a few years ago. Research on the forum called out an issue with the emergency latch, mechanism. This mechanism engages when you drop the top, it locks the trunk and prevents you from opening it when the top is going down. There have been instances when the latch would engage when the trunk was closed and set stuck. this problem was 100x worse on the roadster because if the trunk lid locks, there is almost no way to get back into it.
I don't recall,l all of the details but there are several links to this on the forum. The down side is that you have to remember to KEEP THE TRUNK LID CLOSED WHEN OPERATING THE TOP
It's is a piece of plastic, I just broke mine off so that it would never become a problem.
the previous owner may have already done it and the reason for the missing release cable handle
