Airbag warning - blinking on and off
My 2004 cupe limited had an airbag warning light. I got a new airbag controller (MB part nr 001 8200826) and the warning and initial code disappeared. Then what has happened is that the warning light started going on and off continously - ca 1,5 min intervals. There is a code indiciatng something is wrong with the passenger seat airbag manual override switch ( the key operated switch on the side of the dash on the right hand side); thing is that my car does not have this switch - I have found out that european crossfires like mine (2004 limited) don't have this switch (to turn off passenger side airbag if you have a child in the seat etc).
Does anyone in here know : 1) how to identify the correct version of the airbag controller module that I need - is there a special part number or something I have overlooked? or 2) how simulate this switch in order to satisfy the airbag module searching for something that doesn`t exist? or 3) has anyone else had the same problem and solved it - how?
I spoke to a dealer - he says the module is actually a Fiat part. He also said there are two versions - one for airbag systems with passenger override - and one for systems without the override.
I would be very grateful for any advice as I will not get the car passed for MOT with the airbag warning light blinking.
regards
Espen
Norway
