Old Sep 19, 2019 | 09:09 AM
onehundred80
Default Re: Radiator Problem
Originally Posted by amx1397
very unusual , the only thing i can think of is You are using the wrong coolent. these cars like all Mercedes must use
mercedes coolent.,,, don't beleave me read below or google ,type coolent to use in older mercedes
or just replace the rad every 4 to 6 years
https://www.mbca.org/sites/default/f...reedec04_0.pdf
https://www.googleadservices.com/pag...9aACCFI&adurl=
I am sure that most people here have used Zerex G-05 and not the Mercedes equivalent. Radiators are used with different types of coolant at different ratios so I doubt that a radiator would fail due to the coolant that was used. Zerex and similar coolants are used because of the engine block material. Using the wrong coolant in our engine could in the long run harm the engine.
