Old Sep 20, 2019 | 03:05 PM
GraphiteGhost
Default Re: Torn steering wheel
It depends on a few things, do you want OEM, If you are located at a place where they recover wheels do you want to leave it (your car) with them? Removing the wheel is complicated if you have never done it. There are some here (and I think a tutorial) that steps you through the removal/install process. Search the forum for steering wheel replacement or similar keywords. Remember FIRST remove the negative battery cable and wait at least 15 minutes (tie it off somewhere to make sure it doesn't touch the neg post) before doing any work on the airbag system. IF YOU CONNECT THE BATTERY FOR ANY REASON WHILE THE AIRBAG IS DISCONNECTED, YOU'LL HAVE AN AIRBAG LAMP LIGHT requiring a reset with special tools. Good luck!
