Thread: ecu part number
Old Sep 29, 2019 | 08:21 AM
UrbanE's Avatar
UrbanE
Default Re: ecu part number
Pulling and replacing the existing ECU should take 15 min the info (part number) is on the sticker.
Do you have a way of reprogramming the used ECU? It’s not going to work unless you can have it reprogrammed to your VIN
If you purchase a complete set of electronics from a donor and change all , it will work.
ECU
SKREEM
Keys
ignition
BCM
buy a used ECU, without the ability to program it and it will sit on your bench, Forever
